Freighttrain at springfest
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
59
Norco, CA
Nice runs :driving:
Sorry we missed it :(
To answer your question on DP. Pat is getting a little better everyday :D
He hasn't had a smoke or a drink of any kind in 12 days :eek:
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Nice times
Thats cool to be the fastest. With that mph you should really run good when you get it to shift correct. CONGRATS Jeff
02freighttrain
Team Salad Bartender
Aug 13, 2006
911
sootville, Fl
Thanks for all the nice comments. BoBo's truck had several pounds on me or it would have been a lot closer.
The Dyno results will be posted by Dunbar at some point.
We made 670 with no Map sensor - no Baro sensor - and no MAF sensor.
The motor was only getting around 20 degrees timing in this setup.
I think we only got beat on power and torque by Nasty, Eric, and Landon
I think we made 1160 or so on torque. I've got the sheets somewhere.
The motor never went over 3600 on the dyno with the timing issue.
It also only wound make 45 lbs of boost.
It made 60 at the track.
We did rob a MAF sensor from Eric. Also hooked up the baro and MAP before we went to the track. MPH was much better. The tranny did not like it though.
Time for a co-pilot.
02freighttrain
Aug 13, 2006
911
sootville, Fl
Nice 670, the torque seems slightly low, although it could be the dyno, but when nasty girl did 9xx it was below 1500 torque
There were three other built motors on the dyno (Similar to mine). I think we made more torque than them. We'll wait for the numbers.
The word is that the decompressed motors are making less torque, which stands to reason. It's just fine with me. 8 dyno pulls on Friday, 3 on Sat and 4 passes down the track. I brought it home running:D.
The lower torque figures are just fine with me.
