Finally a better idea on up pipe gaskets!!
RickDLance
1,276
14
Here is our new DOUBLE up pipe gasket!
Both up pipes are combined in one gasket. This makes them impossible to install backwards and makes them easier to install. The two bottom holes are slotted. This allows you too start one bolt in each up pipe and then simply slide the gasket in!
Check ProFabPerformance.com for pricing!
colorado.dmax
Apr 19, 2015
66
It's not like his site is misleading and leads you to believe a set will be included. You should have ordered a set.
