Fan Hub variances
oondy
Apr 12, 2016
Hello all. I have an LLY from a GMC Sierra 2500HD in my GU Patrol here in Australia. I have a sizeable radiator and there is not much room between the fan clutch hub and the radiator.
Does anyone know if there is a shorter or lower profile fan hub assembly from a van or something else that would give me a little more room between the radiator and fan hub?
Cheers in Advance
Andrew
kidturbo
Piston Tester
Jul 21, 2010
2,333
1,103
Somewhere On The Ohio
www.marinemods.us
Nothing stands out to me because they all screw onto the threaded shaft of the fan pully. I have cut that threaded portion off before to clear in marine swaps. One could possibly follow that approach and fab a flex fan directly to the pully. But belt clearance to fan would then be your issue.
