LLY: Factory hard fuel line diameter?
thunder550
1,176
Phoenix, AZ
I'm swapping fuel lines from a crew cab frame over to a reg cab frame, and need to shorten them. I want to do something like the spliced trans lines pictured below, where I run AN fittings and a short length of AN line to splice the lines back together after cutting out a section. Just need to know what the OD is for the factory fuel lines. Anyone know?
fctry286
WhisperMax
Jul 30, 2010
254
San Diego.
I acually just did that to my fuel lines. I ended up running HP rubber line from the cooler all the way up to the motor. I used 1/2" braided line.
If you wanted to get technical you could call up Frank over at EARL's performance 714-962-6555, he could hook you up with some nice line and fittings just like the picture. But be prepaired to pay like 40ea for those red elbows.:thumb:
fctry286
WhisperMax
Jul 30, 2010
254
San Diego.
I cut the metal clamp around the push lock, that push lock has a barb on the end of it. plenty of length to put a line onto and clamp it down.
thunder550
1,176
Phoenix, AZ
Gotcha, that sounds easier than what I was planning on doing. Are you running a lift pump? I'm not currently but will be at some point, want to make sure that whatever I end up doing will hold the little bit of positive pressure the lift pump generates.
thunder550
1,176
Phoenix, AZ
Converted, 12mm = 0.472 inches, and 10mm = 0.394 inches.
Compared to .50 (1/2) and .375 (3/8) inches, I think the -8 and -6 AN fittings will work fine. They are only off by .028 and .019 inches respectively.
Thanks guys!
sweetdiesel
That's better
Aug 6, 2006
10,390
51
Thailand
are you trying to crimp on a Ferrell that uses a jic (A/N) fitting?
you would be better off just running a hose over the pipe ,imo.
but each to there own.
thunder550
1,176
Phoenix, AZ
I was going to do one of these style fittings that uses a compression ferrule that goes around the fuel tube. I think I am just going to use rubber line with some hose clamps though after thinking about it. Should be easier and cheaper, even after purchasing the flare tool.
S Phinney
4,011
Quncy, Fl
I used that type of fitting before in 1/2" and there was zero problems with figment is leaks.
