Tried searching but couldn't find what I was looking for. I've seen the pictures of the stands people have made that mount where the motor mounts go. Just wondering if someone has a link of plans to build a set?
Use a regular 1k LB engine stand. Get a piece of 1/2 plate and drill the four motor mount bolt holes. You will also need a piece of pipe aprox 14" long (same OD as the engine stand mount). Cut a 45* cut on one end of the pipe and weld it to the motor mount plate.
