engine doesn't sound well.
rsq10
Nov 26, 2013
3
I had recently added fuel and was driving on the interstate. The engine light came on and lost power. On star diagnosis was problem in fuel system. Any suggestions?
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
It could just be your fuel filter may have water in it.Do you treat your diesel with power service or any other treatment? Could try heet approved for diesel to try and take out some water depending on how much you have in there.May have to empty the tank and get some good diesel from a known to be good sorce.
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,368
Berthoud, CO
Could be lots of issues causing it. The erratic noise makes me believe its an LLY and may have injector harness issues causing it to run in 4 cylinder mode.
rsq10
Nov 26, 2013
3
Sound like its not running on all cylinders
Sent from my AT100 using Tapatalk 2
