I see you have an 01 with moonshine tuning listed, so chances are you have an 6006 02 OS in it. You will need to have your VIN number changed to that of an 02 to have the EDGE work properly as the PID list for an 01 does not properly work with an 02 operating system in the ECM.
i just went thru the same exact problem. if the the vin year of truck does match to the year OS your running the edge gets confused and says can not read PIDs and turns off. there is one way to kinda trick it and still use an 02 OS i figured out thru trial and error. then i read why i think this certain OS works it is for early 02s so im guessing it was in some very late 01s so then the edge thinks its 01 OS. find this 2002 year with OS 15077860 CAL 15077863. if your having trouble finding it PM and ill email you a stock file of it.
Hello,
I just picked up an edge insight cs2. I’m only seeing , Ect and boost. Am I missing additional pids? I have a 2017 GMC Canyon 2.8 duramax. I was gonna add an egt probe this week. Anyone have good information. This is kind of over my head.
