Duramax block strength
joegorby
Apr 12, 2012
98
40
Washington Pa
Here's a pic of it
Sent from my SM-G930V using Tapatalk
rcr1978
790
Spring Creek, NV
Are the girdles helping the blocks at all? Are stocks caps with a girdle even a worthwhile upgrade or should a guy do billet caps and skip the girdle or do both ?
I skimped on the billet mains and got a girdle but word is the one I have may not help it's (Industrial/Randy's one).
Chad006
Drag racer wannabe
Feb 12, 2015
311
5
Goodlow, B.C.
Was wondering the same thing.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
I don't really think the girdles do anything on a Duramax. Not convinced the billet mains help anything either.
However, if your spending the money on a big build, I wouldn't talk someone out of either one because I'm sure they don't hurt anything.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
My truck has been in the 1100-1200hp range all season with many many passes on it. Stock caps and girdle. No filled block. Also LB7 crank. Street it a lot. I think clearances and maintenance are huge.
ikeG
Oughta Know Better
Apr 19, 2011
2,431
128
Western PA
www.facebook.com
I don't think new oil or 10,000mile-old oil would make a difference in all these cases. We're not talking about spun bearings or such.
I think cylinder pressure has everything to do with these failures. Too much timing (same thing basically) will kill hard parts when we're pushing them this hard. That's why broviaks cyl pressure measuring tool on the dyno is worth it's weight. Ive always tuned our truck but never engine dynod it til this year. After dialing it in and gaining bunch of power, we Gained another 5 hp by pulling 2* out of it. So after the damage we did last year on that tune, we were able to gain power but i guarantee it's easier on hard parts this year.
Sent from my XT1585 using Tapatalk
S Phinney
4,011
Quncy, Fl
Most everyone's builds will be fine with stock main caps and a good girdle. The limits of stock blocks is around 1600 before you need to do full fills. Then it's not streetable. My newest race motor is half filled like all my others and has billet mains and girdle. I have not had any problems with bearing wear from walk or anything else. Clearances and assembly is crucial in all of this.
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,059
260
At Da Beach
So how many duramax block failures have you seen or know of that weren't caused by assembly error or another part failure? It isn't something I see commonly talked about like rods, pistons, and cranks, but there aren't that many 1,000+ HP trucks running around either.
It's not like we have a 53 block. Ocasionally there are going to be casting flaws, dropped blocks, machining/assembly errors, etc. But I see your point, seems Duramax blocks are stronger in stock trim than a Cummins horse power for horse power. Torque is a different story though...
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
I think it makes a huge difference when you are talking looser clearances. Just by switching from Schaffers to Penn Oil I seen a 4-5 psi gain in oil pressure. Use to be 18ish at hot idle. Now it's 23. Also the amount of soot in oil.
ikeG
Oughta Know Better
Apr 19, 2011
2,431
128
Western PA
www.facebook.com
I'm wont argue that. We increased oil clearances a bit on this new engine and run wicked oil pressure. And i believe the clearances and machining can make or break it. A girdle would take care of the problems were experiencing, but the bearings are fine and we also backed the average power down some.
I'm not saying that it cant be prevented, just that no matter how many parts you use and how tough its built, it's still subject to the same torque, cyl pressures, etc. Like in gorby's case, that's pretty extreme. Would billet main caps and a girdle prevented that? Maybe. His crank basically pulled down on the main stud enough and the stud didnt fail, so it busted the block.
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Blocks
I split cylinder walls at 1000 hp on my first motor in the white truck. I then hard blocked it had 8 sleeves put in and no more problems with that block. All the others have been good with a half fill on the blocks. All with stock caps and no girdle. I'm not a believer they help much either. It cant hurt anything to have it done if you have the extra money.
D1rty-max
Spare some change?
Jul 16, 2015
132
Longview, TX
Honestly didn't think the block was even an issue at 1000hp, Id also think a girdle would help since its supposed to evenly distribute load across all mains.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
The girdles that people are using in a Duramax are kind of a joke. That's part of the problem. There isn't room for whats needed so they sell everybody these flimsy little 3/8-1/2" thick or so girdles and tell people they solve everything.
Look at tractor pulling, those guys are using 1" thick and sometimes thicker steel girdles. And I've seen them shear even those.
I'll say again, I think a girdle might help, it definitely won't hurt, but it's not doing near as much as some people think in my opinion.
CurtisEmery
Mar 21, 2008
486
Ontario, Canada
We cracked a bore last season with a half filled block @ just over 2200hp measured on an engine dyno. Engine has billet mains and gurdle no deck plate. This season fully filled block and solid iron heads engine is still running strong. Hopefully everything looks and measures good on disassembly at the end of the season.
ikeG
Oughta Know Better
Apr 19, 2011
2,431
128
Western PA
www.facebook.com
Evil diesel truck?
