Duramax/4L85E wiring
MAXX IT OUT
<<<IT WORKS
Mar 1, 2013
1,774
Des Moines, Iowa
How do the factory vans run the 4l85E? I have finally found a engine and trans for my c10 swap, but it doesn't have the ECU's or body harness. How different is the van harness from the truck harness? I have a truck harness and that I was planning on making a standalone, but I am not sure I want to do a manual valvebody or a separate standalone trans controller. I have a ls 4L80E wiring I could use, but I don't what GM used for a TCM in the Vans.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
GM used the T42 TCM for the 4l85e behind the duramax. The ECM is pinned slightly different so you can't run a truck tune in a van or vice versa, but the ECM's are the same so you can flash in a van cal to a truck ECM if needed. I haven't done it, but I know others have repinned van harnesses to run with a truck cal and allison, so I don't see why you couldn't do the same in reverse if needs be.
13,605
640
I repinned my van harness to run a truck cal with the T42 because I wanted to be able to run a DSP OS.
