EFILive DSP5 Tuning Question
uwyo_dmax
Sep 17, 2008
190
35
Laramie WY
Since the only altitude tables we have in dsp mode are table (c) what do you guys do to stay on timing table (c) so each dsp will get the right timing table? I thought i had it but when i went home for Christmas which is alot lower altitude than laramie (7300ft) I started getting some timing rattle. After doing some logging it looks like the only table Its using is (a) So it was never getting any of the dsp timing tables.
Thanks
Justin
uwyo_dmax
Sep 17, 2008
190
35
Laramie WY
You could have ABC all the same or try altering b0902-907 that might help
Thats what I tried doing was b0902-907 but apparently i did it wrong. Will the dsp tune automatically run the timing table in that dsp position no matter what timing table the stock tune would be commanding?
2500HeavyDuty
Book 'em, Danno!
Feb 14, 2008
2,209
Katy, Tx
www.myspace.com
log the parameters from the tables in b0901-b0907 and make sure values in the cells are correct. also when i had my b0901 table set to MAF it was only using table A and im sea level where i live.
mine will use a and b when doing normal driving and when i get on it itl go to c when b0901 is set to MAP
uwyo_dmax
Sep 17, 2008
190
35
Laramie WY
Went and logged it the baro was 11.3 the whole time which should work i have b0907 set at 10, and 906 set at 15 so i should never see A, or B tables yet it still seems to be running off table A (which is still stock) all the time i didnt see anything over 15* of timing with my hottest tune.
uwyo_dmax
Sep 17, 2008
190
35
Laramie WY
No that table is all at least 25* I'm going to try reflashing it, its been so long since i put this tune in i cant remember if I had it based on maf and have since changed that in this tune.
