Drive Shaft Loops
DuramxMan
71
AUBURN, GA
Wondering what everyone is running for driveshaft loops? Went to Crossville, Tn for ODSS and was told I need to have them when running slicks.
3,927
1,082
Neenah, Wisconsin
I have DHD's full shields. I would venture to say they are the best available for our trucks and honestly installation was a breeze plus I know they aren't going to fail. I went steel as they were considerably cheaper. On a full out drag truck I could see getting aluminum.
coker6365
Coker6303's ***** Daddy
Dec 4, 2011
486
I have the DHD Aluminum on the rear of each shaft and homemade steel loops from a cheap summit kit on the front of each shaft. If you don't want to spend the money on the DHD stuff, the summit kits will work fine with a little modifications. I think James has a thread on here somewhere with some pics on them.
13,605
640
The summit kits won't work on the rear aluminum shaft unless you section them to add a considerable amount of width. They barely fit with the significantly smaller steel shaft.
5,097
yeah the ones i modded were for steel driveshafts. the rear aluminum one aint gunna work with the summit hoop/
coker6365
Dec 4, 2011
486
Ah, I didnt catch the alluminum rear shaft comment.
Sent from my SM-G965U1 using Tapatalk
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
My DHD aluminum drive shaft shield after my drive shaft broke a couple weeks ago...
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
Zak did the shaft still come out or did it hold?
It happened during a truck pull, when it broke the drive shaft yoke it pushed the slip yoke onto the output shaft and was stuck on there. So drive shaft didn't fall
all the way out, but drive shaft shield was laying in pieces on the ground.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
It ripped the 1480 yoke ears right off a custom built 5"x.125" aluminum shaft...
