Drag racing questions?????
02duramaxfan
May 13, 2013
25
virginia
Yeah I had it data logged twice he made some changes for me...Im just one of them guys that doesn't like nagging people all the time.
I didn't know if maybe I just wasn't doing something right so I would ask y'all on here.
02duramaxfan
May 13, 2013
25
virginia
I let has a djm 3/5 drop and Qa1 shocks on it
Air pressure was high like 40-45 I just assumed since it was when 4x4 that wouldn't matter that much
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
35
Goodyear, AZ
It does matter, but for what it's worth with a simar suspension setup to you i cut a 1.7 my first pass ever.
There are just so many variables. Altitude, humidity, wind, track prep, track temp, air temp, tire temp, tire pressure and so on.
Burn Down
Sep 14, 2008
7,093
Boise Idaho
I meant traction bars or spring clamps? My bud Reece has pulled 1.6 60's with worn out shocks, 20" 420's, & Long traction bars. I can't remember what his tire pressure were but they were low, 25-28 front and 20 ish rear.
This^^^ so many variables...
It's not one thing but rather a combo of things that will make you fast or slow:thumb:
5,067
so many variables here.
that 83 turbine and 1.10 housing is not helping spool up at all
have you gone through the front end and checked for any loose or bent?
what are the shocks set to for the track? dual or single adjsutable?
cal tracs or axle wrap bars on the ass end?
how long have you let the trans learn to the new tunes and WOT shifting?
what size tire are you running?
ScreaminDuramax
Sep 19, 2013
345
Torrance
I was having the hardest time getting out of the hole and cutting good times with my 420s, I didn't feel like airing down at the track since I didn't have a air pump. I was getting frustrated with my times and my hop off the line. aired down and all of my problems went away. I went 22 in the front and 20 in the back. cut a 1.65 60' and ran my fastest time, now I cut consistent 1.6x 60'
02duramaxfan
May 13, 2013
25
virginia
Yes I have traction bars on the rear
I also have a straight center link on the front end
I am running 305/50s for tires
The new tunes have been on for for roughly 1500 miles and I have prolly 4x4 launched it roughly 10 times
02duramaxfan
May 13, 2013
25
virginia
I am going back to the track on Friday to get some more passes in
I will just air the tires down and give it another shot
Anybody know how to upload any videos I would like to post one up from last weekend see what y'all think
5,067
upload them to youtube. i can tell you alot from a video (if they are close enough to the truck)
DMAXchris
It’s only temporary!
Apr 28, 2009
2,274
Natrona Heights PA
You need to take your time and let some heat build in the turbo. Gotta have at least 1000* on the egt gauge. The Garrett turbo will come up faster since it was ball bearing.
If its pushing through the brakes change the power steering fluid. If that doesnt help check for wheel speed sensor codes. Maybe a 2nd gear start will be needed because of the taller gears.
The 83mm turbine will rob you of power. You might make 50 less hp compared to the 87mm. The Dmax likes an 87 with a 1.0 a/r.
5,067
https://youtu.be/aTiBG61KPN4
https://youtu.be/es4d0USJ3gQ
Here's two videos.
I used my brothers account btw
first vid, you left too hard and the truck has a bad bounce. i cant see what your front tires are doing but you shocks need tuning. second one you didnt leave hard enough.
the no smoke i can bet you money is from you hitting the rev limiter cause you are blowing through the converter bad and not hitting lock up till the point the smoke clears (cause the ECM has pulled back fuel from hitting the rev limiter)
02duramaxfan
May 13, 2013
25
virginia
In the first video I left atound 15 psi and it did hop... Could that possible be to much air in my tires
I thought about getting a lock up box but everybody told me that the tcm tune was good enough I'm still on the fence about
And should it smoke more while I am trying to spool it I feel like it just hazes during and then after I launch it fuels hard
ScreaminDuramax
Sep 19, 2013
345
Torrance
I have had multiple people tune my TCM and I still cant get my converter to lock like it does when my BT lock up box is on Auto mode, its perfect for drag racing. Locks as soon as it clicks in to second and doesn't unlock till you let off. Worth it in my book,
Once you air down you are going to be amazed, your first launch was what my launches were like before I aired down
5,067
The hop is from something unloading. Suspension or tires or something else. That video is too unclear to tell what it is exactly.
Are your shocks not adjustable? You keep passing by that question and suggestion about them
I know of plenty of guys pushing 1.6 60s at 40-45psi in those tires. Too less and the center of the tire rolls in and you loose traction. What that point is is different on each setup
Tcm tune is not the same as having someone make it a lock up tune. Depending on how old that tcm tune is, it could have been before we had the tables to make the TC lock up in second like it should. Specially if that was an old sled puller, TC lock up isn't an issue like it is drag racing
02duramaxfan
May 13, 2013
25
virginia
Yes the shocks are adjustable
The truck with the same suspension set up last year cut 1.6 and ran like a scolded ape it the same tcm tune as last year nothing changed in that regards
I changed a few things and now it won't do it hell it might just be the driver....
Just trying to get things figured out on this truck
