Diff rebuild recommendations
dndj
Boost!
Apr 13, 2019
302
33
Oregon
Hey folks in the PNW, looking for recommendations on who would be good to rebuild the rear end of my 03 LB7 in the Portland, OR area. The ol' G80 gov lock decided it wanted to stay locked for good today and not release with about 140k on the clock.
I have used Six States in the in the distant past and they did a great job. Are they still pretty much the go-to guys in PDX? I also had a very bad experience with Paden Drivetrain 15 years ago and won't be going back there any time soon.
Also consensus seems to be to not bother rebuilding the G80, looking at Truetrac as a stronger alternative. Not really interested in the Grizzly or Detroit Locker, truck is a DD and I want really good street manners.
Thanks
Bdsankey
3,914
1,074
Neenah, Wisconsin
Thanks
I cannot comment on a shop, but I can comment on the components. I would personally go with a Truetrac, they are much improved over stock and will actually act like a LSD. They are 100% worth the money. The G80, even if you rebuild it or replace it, will do this again. If the truck is relatively mild I wouldn't worry about upgrading axle shafts or anything else that hasn't failed. Depending what happened the ring and pinion may still be good as long as they haven't seen large metal pieces.
c5fourj
Occasionally moving quick
Dec 20, 2014
307
3
Brighton, CO
Just had a truetrac thrown in my truck this summer, as my diff quit locking. Great street manners and I never look back. I wouldn't hesitate to get it.
dndj
Boost!
Apr 13, 2019
302
33
Oregon
Thanks guys. Really appreciate it. Just ordered up an Eaton/Detroit TrueTrac and have an appt set up at Six States to get it installed on Monday. They also recommended I put all new bearings in since i'm getting up there in mileage, so I'm going to go ahead and have that done too at the same time.
In case others are looking, this is the unit. https://www.eaton.com/us/en-us/skuPage.915A568.html
3,682
236
I have a TrueTrac in my '03 for a couple years now and love it. They allow more slip than the G80 in extreme situations (one tire on ice, one on pavement, etc.), but it will transfer the power after a bit and get you moving. On normal roads it's fantastic, puts power down really well and never hits hard or destabilizes the truck. And unlike the G80, it will survive 700+ HP more than once.
dndj
Boost!
Apr 13, 2019
302
33
Oregon
Well I had the guys at Six States swap in a TrueTrac today. Kind of a beast, weighs around 65-70 lbs without the ring gear installed. Thanks for the recommendations, I've heard nothing but good things about the unit.
Just for fun I took some pictures of the G80 gov-lock carnage (Grenade-80 or gov-bomb , your choice ;)), figured I would at least get a little entertainment added in for my $$$. Normally in a G80, there is a spur gear that sits behind the drivers side spider gear which drives the flyweights. This gear also has machined ramps which engage with the ramps on the back side of the spider gear and force the clutches to lock up when engaged. Video here if you want to learn more https://www.youtube.com/watch?v=ftyJvIO0DZ8 The spur gear was basically shattered and wedged between the spider gear and clutch pack leading to the G80 being stuck in the lock applied position. On the opposite side, the flyweights and little pinion gear shaft which engages the spur gear appeared to be OK.
Also drivers side carrier bearing was wasted. Passenger side looked OK. I didn't check the pinion bearings, but all were replaced. Ring/pinion gears appeared to be fine so they were reused.
CDmax16
60
5
55
NNV
I just switched mine out with the Nitro torsen style and 4.30’s. These things are beastly.
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,039
246
At Da Beach
My g80 had a crack in the carrier all the way across that was a 1/2" wide in a spot. It was still working just dragging drivers side on right turns.:rofl:
dndj
Boost!
Apr 13, 2019
302
33
Oregon
Wanted to report back - Six States in Portland, OR did a great job installing the True Trac, setup must be right because the rear end is completely silent, original ring/pinion were in good shape and reused.
Good Lord this thing is effective - wet or damp roads = instant sideways with a bit too much go pedal on tune 3. :eek: :D Wish I would have made the upgrade sooner. The G80 kicks out at 20-25mph by design so it had limited effectivness anyway.
Thanks for the recommendations.
N2BRK
1,907
233
Love mine. I’ve had it for about 5 years.
That ain’t carnage- lemme upload a few pics of my buddy’s 1500 rear. Ouchie. Lol
35” tires, lift kit, woo-tan-Wind-warrior, and an angry foot.
dndj
Boost!
Apr 13, 2019
302
33
Oregon
:rofl: Wow. That's nasty. :eek: Amazing that GM has shipped these for so long with the bad reputation they've earned.
4,963
They work well for their intended purpose and was one of the only mfg that offered the closest thing to a locker for a long time in a truck. Till the late 2000s when ford started putting e lockers in
They just don’t like abuse. Coming around the corner and standing on the throttle, causing one tire to spin fast/hard and then the locker hitting with all that built up momentum is going to hurt things after a while. Add bigger tires or more power and it just makes it worse. When clutches start to wear, you gain more “dwell” as well which just lets the tire spin more/create more inertia.
I agree through. With what’s out there for options, it’s time for gm to update the 40 year old tech
KyleC4
470
Bay Area
They have the tech. They just need to get a supplier on board with a design change to be implemented. But I also understand how that’ll probably increase the cost of mfg per unit and that doesn’t sit well with everyone up top. Cause can these new vehicles get any more expensive? 2019 Premier Tahoe with all the fixens’ had a sticker on it for $90k......ouch
