Did LML def and complete EGR delete new radiator and Intercooler and still overheating
rrh13441
42
Yes I did a def delete first, 5” exhaust, H&s tuner. Ran and towed great.
Now I did radiator and Intercooler, new fan clutch, t-stats, water pump, hoses and full EGR delete. Now cooling issues
Mikey52
118
29
I would guess then that your fueling is off some. In your tune, if it has overheated enough times I would also suspect head gaskets. Someone else asked earlier about the bypass line for egr cooler, you did add one and not just block it off correct?
1,612
Moved this thread into LML. Moved the tuning posts into the OP's tuning thread. Hopefully that made sense......
Reactions: 2004LB7
9,903
149
I’m going with bad head gaskets by the sound of the things he’s done and has going on.
rrh13441
42
Everything pressure checks good now that I changed the water pump and fixed my oil leak.
Nate’s Dmax
178
42
Also be prepared to swap your Mishimoto radiator out in about a year or less. Anyone looking to put a Mishimoto radiator in needs to search the forums. They are junk. But anyway hope you have your issues resolved for now.
