Need some fresh eyes and people smarter than I with this one before I start tearing my built motor back down.02 lb7 trip cp3 with fingers controller,getting full rail pressure at crank and also setting a crank position code (0336)3.5-4.5 volts at fpr plug.fprv is removed for the 3rd cp3 inlet in the fuel block.Switched the cam and crank sensor to make sure I didn't mix wires and have swaped the valley fpr as well as tried each pump by them selves with the same outcome.Its trying to fire but will not and when its chugging almost sounds like a fuel knock.sorry for the novel but wanted to give as much info as I could,Starting to think this block is cursed.Thanks in advance.
