Coolant hoses breaking
Durohill203
Jan 27, 2021
I have a 2011 3500 has just 21000 miles I just bought the truck. I had all new coolant line put in along with other things. It has blown 2 brand new coolant lines right off the fitting. The shop I brought it has pressure test it everything came back perfect no white smoke. The shop believes I have a cracked head causing pressure to blow the lines. I find that hard to believe. Any feedback would be great.
Dozerboy
4,826
402
TX of course
Should be blowing it out the overflow before a hose coming lose if the cap isn’t screwed up. But if a unfortunately blown HG are not uncommon on all the newer trucks.
1,779
try a new cap, but like others mentioned, it is not unheard of for the head gasket to blow causing excessive pressure in the coolant system
Reactions: Nate’s Dmax
scramHD
112
Tx / MS / AL / MEX / FL
If its the lower radiator line blowing off its not pushed up far enough and/or the retaining clip is not in the groove and/or missing.....it wont blow off until its good and hot....and will hold a pressure test....been there..
