Converting LBZ tunes to use in LMM
pl_silverado
100
71
I've been on the other max forums forever, but this seems like the place to go when it comes to these types of questions. So after selling off my lml's, and totaling my lbz which was absolutely the best running truck I've ever owned, I am left with an LMM. I have a perfected (imo) DSP5 tune for my LBZ that i'd like to somehow utilize in my LMM. Is this possible? The LBZ was an 06 and the LMM is a 10.
pl_silverado
100
71
Just copy and paste the tables. If you made a LBZ tune you can make an LMM tune. They’re basically the same. Just watch to make sure the axis are the same.
That was my plan, but then I saw the LMM has a lot more tables that do not appear in my LBZ like all the different altitudes. I will try copying the tables that appear in both and see where that gets me.
gmduramax
Shits broke
Jun 12, 2008
4,045
226
Nor cal
You should adjust the tables for altitude but if you just keep them all the same you won’t have a problem
1,735
Except when you do drive at a higher altitude it will run like a dog. At least mine did until I adjusted the altitude tables to compensate
Reactions: gmduramax
pl_silverado
100
71
So I can make all the different altitude tables the same as whatever the matching table is from my lbz tune without issue ?
