Help: Code P0299??
Clay A.
Jun 15, 2009
23
My truck keeps throw a P0299 code. It says turbo charger engine underboost. I'm not sure what it means or if I should worry about anything. Can anybody tell me what this is and also how I can fix it. Thanks!
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,149
Wilmington NC
www.mydieseladdiction.com
It means you are getting less boost than what you are demanding. You can either log and find out where in the B2204-B2209 tables this is occurring and demand less boost in that area, or your can cheat and change C0804 to allow more room for error.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
33
Lexington, Ky
thanks!. could this mean i have a boost leak somewhere?
I do believe so because when I had my boost controller set up and didn't have my egr blocked it would throw it all the time. Do you have a ppe controller? Even after I blocked the egr it would put up on a cold start within a couple minutes if it was turned up any
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
26
64
Norco CA
www.mcratracing.com
OK, this is the story.
Back when the LLY came out, and people started putting on either aftermarket aircleaners, EGR blockers, or exhaust systems, AND they went driving in the mountains, the infamous P0299 Underboost code came up. It is a performance limiting code, so it was important to resolve. It was often accompanied by MAF codes.
What was happening, is that since you altered the air flow going in and out of the engine, the MAF sensor reading + the baro sensor reading, did not line up with the boost sensor reading. So the GM computer "guesses" at what is wrong, and it figured there was a problem with the boost. The boost sensor itself still was reading OK, the turbo was fine, but the MAF reading was different we found.
So it is unlikely that there is really anything wrong with your truck UNLESS you are bone stock.
The easy fix is to increase the boost error limits to 15 psi, IIRC, as Othergirl posted above. Trying to "recurve" expected boost is fine, editing the MAF sensor scaling, etc, will all git-er-dun but the boost error limit is the most reliable way of killing it.
Cougar281
1,757
215
St Louis, MO
On a realated note, I get a P0299, but ONLY when the truck kicks up to elevated idle when it's cold. I've been pulling the freeze frame data each time I get it, but haven't checked it yet. My intake is a stock 06 intake, EGR fell off, and I have the GM update that includes the calibrations for the 06+ airbox. Ideally, I'd like to fix it without "compromising" the test it's self, so if I actually DO have a problem, it's detected. Thoughts?
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
I've been getting this code since I put my nozzles in. like said usually in the first few minutes after a cold start. Happened once warm though while cruising the interstate.
othrgrl
Mar 10, 2008
2,149
Wilmington NC
To fix it without "compromising" the test you would need to log it and pull boost out of areas of the table where it cannot meet your demands.
fast03
1,201
60
Rancho Cucamonga
So i am helping a friend that has an 05 lly. he has this code p0299 after intake and exhaust. so i should set his C0804 table to 15 all the way down? he is running the basic 20/20 tune for lly's. thanks in advance.
steve
imfromthecountry
Jan 2, 2012
The same thing happens to me as well when the elevated idle kicks in,it will run in high idle for a while but then throws a code and goes back to idle. I have found the culprit to be in the P2225 turbo vance position minium table. I have my table modified to 5% vane position at idle to get an exhuast rumble. If I put it back to stock values I dont get the underboost code anymore. I have heard the LLY E60 PCMs dont like some of the programming changes you make with some tables and it does quarky stuff. My friend has a LMM and his truck works fine with the same settings as mine. Though it is rather confusing since the high idle doesnt reside in that part of the table I modified.
sweetdiesel
That's better
Aug 6, 2006
10,390
51
Thailand
I use to get that code also from high idle. give me a bit and ill figure out what I did.
search that code on here in the mean time.
306LBZ
The Man
Jul 25, 2012
Saskatchewan , Canada
I've got the P0299 code 3 or 4 times in the last week or so. I have a EGR Blocker Plate installed and mild tunes from Idaho Rob at ATP. What is the cure for this and aside from saying low boost detected what does this code mean(like what part am I going to need to change?) I haven't noticed any problems or issues with the truck even when the code is present. Is this the first sign of needing the Turbo Vane Position Sensor replaced?
socofarm
Nov 7, 2013
Gainesville, TX
Turbo Booster code
My truck will throw a turbo booster code when I'm pulling a load every now and then, mostly on long hauls. I have a 2002 2500hd duramax with getting close to 269k miles on an original engine and transmission. even when the engine light is on when it's throwing this code, it pulls fine and still runs cold. just don't like seeing that light on when I got 800 miles left in a trip. anything I can do to help keep the light from coming on and throwing that code? I wanna say the last time it came on it was the P0299 code, but this time the light went off before I could plug it up.
