This an update on the Cheap & Easy 2000 in this forum.
I took a second HP Slimline Business computer (these can be had for under $130 at TigerDirect, look under refurbished) with a PCI-E slot, and put an nVidia GT430 in it. These can now be had for $65 (http://www.newegg.com/Product/Product.aspx?Item=N82E16814187121&cm_re=GT430-_-14-187-121-_-Product). That Sparkle in the link is the one I'm using, and it's generating ~9500 PPD by running it at 800 mhz. At the factory settings, it's just about 9000 even. It comes with the Low Profile bracket. Just like the GT220, very simple to install.
This is a little louder, and you can notice that it is running, but it's not bad. Given the low price difference, and still "mild" behavior, this will even be a better fit for our needs. I was stunned by the large PPD difference in similar priced cards.
The reason I tested the GT220 was simply because it was in the machine before I learned of FAH.
