Catastrophic
ikeG
Oughta Know Better
Apr 19, 2011
2,429
128
Western PA
www.facebook.com
New customer brought their limited pro stock pulling truck here after it locked up. Check out all the damage.
Sent from my SM-G960U1 using Tapatalk
815
wow. Let the JB Weld promotional staff get ahold of it. they'll fix it right up 🤣
I was thinking Flex seal would seal it back up... :ROFLMAO:
Either way it Would make for a great Viral video... Patch it up and send it again...
Slap a used crank in it, put the rods in a press and straighten them, a brass tube in the oil galley with JB weld... Fill the block so no water jackets...
People would go bananas.
Some one really should do that with all the scrap parts they can salvage. It would be epic!!!
Reactions: 2004LB7
1,608
Wow. Crazy to see hi-po rods look like that.
So are you thinking build error or parts failure?
ikeG
Oughta Know Better
Apr 19, 2011
2,429
128
Western PA
www.facebook.com
Super large bore size, 30ish hooks on it. Im not sure what happened first but the split block is just gonna happen at this level. Ideally should be deck-plated to run this bore size.
The new engine will be the smallest bore size that will fit the valves.
ikeG
Oughta Know Better
Apr 19, 2011
2,429
128
Western PA
www.facebook.com
Stock crank.
This exact build can hold up at this level, but of course its not a surprise when some things happen. But so far there's a possibility of a bad air to water intercooler, leaking water into charge pipe. The owner has also admitted to using ether to get it started last couple pulls, probably due to low compression with cyl wall cracked. Also admitted that there was bearing material on the oil filter pre screen a couple pulls ago.....
1,754
you think garage54 can weld all that back up?
my first thought was some kind of hydro-lock. your explanation makes sense. even if it wasn't, enough water down the cylinder wouldn't be good for lubrication
Cougar281
1,755
214
St Louis, MO
I bet they'd give it a whirl! Lol
Sent from my Pixel 5 using Tapatalk
darkness
1,228
319
vegas
I would’ve guessed stuck injectors.
Reactions: juddski88
