So i have a turbo at work here and its off a cat c-12. specs are .60 a/r intake, 1.08 exhaust, 74mm compressor wheel. Was wondering if it would work in a twin kit??
A GT4508 should have an 108mm impeller exducer, right? That's a bigun.
The common turbo for a c12 was a 4294, its not a off the shelf 4294 though it was tweeked for cat, wheels should be the same, housings (especially the exhaust housing) was done for cat!
Hers a link to one, dose yours look like this?
http://tristateturbo.com/rebuilt-tu...turbo-gt4294bs-cat-c12-360-430-hp-detail.html
The waste gates were set between like 22 and 28psi depending on hp of engine, would actually work well in a mild manered twin setup!
