DESCRIPTION
The COV is located on the front cover of the high pressure pump.
The Cascade Overflow Valve has three functions:
- regulation of lubrication fuel to the internal moving parts of the high-pressure pump
- regulation of the fuel pressure being supplied to the Fuel Control Actuator solenoid valve
- return excess fuel to the fuel tank
This regulated internal pressure is known as housing pressure, and is determined by engine displacement and power requirements
OPERATION
The COV has a spring-loaded center spool-piece that has a drilled channel with three passages: one for initial low-pressure lubrication, one for lubrication at housing-pressure , and one for overflow. The valve is operated in three stages based on the level of pressure at the inlet.
Stage 1
When the fuel pressure entering the tip of the COV is between 0 and 3 bar (43psi), pressure is too low to overcome regulator spring tension and fuel flows through the center channel, only . This passage always allows fuel flow through to the pump center-ring and lubricates the pump bushings and internal moving parts. This circuit also allows air to bleed during initial cranking and returns the air to the fuel tank.
The COV is in Stage 1 during cranking, only.
Stage 2
When the fuel entering the COV exceeds 5bar (80psi), but is less than 12.4bar (180psi), the spool-piece moves against spring tension aligning a second passage for lubrication purposes.
Stage 2 can be reached during cranking and initial start up.
Stage 3
When fuel pressure exceeds 12.4bar (180psi), the spool-piece aligns with the overflow passage. This stage relieves the pressure into an overflow circuit that sends the fuel back to the inlet side of the gearotor pump, thus limiting maximum fuel pressure to 12.4bar (180psi).
Lubrication fuel continues to flow through all channeled passages during this stage.
Excess fuel is sent back to the fuel tank through the fuel-return circuit
Stage 3 is reached at over-pressure
