LB7: cant get cp3 pump off
garychev
Sep 23, 2010
Ringwood NJ
:angry5::mad: Everything is off got all 4 bolts out of the cp3 from front, I am prying it out and it will not come out . Is this normal is there a trick I don't know??
paint94979
Beer Nazi
Sep 18, 2006
11,714
There is an oring that might have caused it to stick but if you are prying on it it should have popped loose
Kappa9012
MAN.... I Broke it again.
Aug 5, 2008
694
Peoria Il
it should be really loose and you have to finish with a lot of cussing and screaming to get it out... wiggle the shit out of it.
BHoward6.6
West Coast
Feb 9, 2011
274
Huntington Beach, CA
115192921
  1. Remove the fuel injection pump bolts.
IMPORTANT: Be careful not to damage any mating surfaces.
  1. Remove the fuel injection pump from the block. Use 2 screwdrivers to work the pump from the block towards the rear of engine keeping the pump straight.
  2. The fuel injection pump may need to be rotated in order to remove it from the vehicle.
eagleford hauler
Jun 11, 2013
cam gear
On mine I had to pull the little tab with one bolt holding it on the front of the block about cp3 level. Use a suitable tool (that is what the gm manual says) I used of all things a door knob line up tool the cam gear is spring loaded push towards the pasengers side while pulling the cp3 off. Installing is the same.
paint94979
Beer Nazi
Sep 18, 2006
11,714
I dunno I always pry a little at a time on each side and walk it out. Not insulting you but you have got to be doing something wrong
03_DMAX
Aug 15, 2010
124
Take the oil fill tube off and use a bar against the shaft and it should come right out.
13,598
632
That has always worked for me. Just don't get too crazy with the bar and break the front cover.
paint94979
Beer Nazi
Sep 18, 2006
11,714
As you're backing it out you'll need to start rotating it towards either the DS or PS but the regulator side comes out first.
