LMM: Can I use a mahle piston alongside oem pistons?
warpspeed
Shadetree
Feb 10, 2012
45
Ohio
Do you know if I can use a mahle piston alongside oem pistons?
I have to replace one piston in my LMM.....my options are $40 used stock piston from henry, $95 mahle piston, or $175 oem piston.
Mahle is closed today or I'd be calling them. Part # 224-3709
From what I gather Mahle didn't make the lmm pistons so thats why I'm double checking.
I'd sleep best @ night if I put a new piston in.....& thats what I plan to do IF the mahle will work with the other 7 stock pistons.
*Sorry I'm not replacing all 8, don't have adequate funding & not going to be pushing this motor so upgraded parts aren't necessary. The other 7 are perfectly fine, #6 had a hole thru it from the previous owners hot tune.
PS: if anyone has a LH Intake manifold for cheap pm me!
Jscherbs
PIN IT TO WIN IT!!!
Oct 27, 2009
753
Canton, MI
I would buy the new oem one but thats me.
im sure the used stock piston would work just fine. Henry wouldnt sell you junk.
