LLY: Broken piston skirt
bimmer95
82
Morgantown Pennsylvania
I'm not convinced that they're as bad as some people make them sound...diamonds have a steel ring land insert which helps some with ring wear..an .007 ptw clearance I think is what they recommend which isn't that bad.an a little racket when they're cold isn't bad to put up with...
Sent from my SAMSUNG-SM-G935A using Tapatalk
5,097
Diamonds will be fine in his truck. Like he said, the steel ring lands they have makes the difference.
S Phinney
4,011
Quncy, Fl
Make sure you talk to a Diamond about those pistons before you spend any money. They said they have had some issues with those. Check first!
