Has anyone had the front rubber brake lines rupture while stopping???
I'm not sure if that's what happened to my wife's 02 tonight or not. I was running along at nice clip & laid on the brakes heavy to make a turn & right about when I was going to turn the peddle went to the floor & I missed my turn. My initial thought was I glazed em but the further I drove the more that didn't seem logical as I can't think of why the pedal would go to the floor if I just glazed the pads or rotor. So I got to a place I had enough room to loop into a big driveway & get stopped. It'd hold it stopped but the last 1/2" of pedal movement is only stoping power it had.
Got out to find brake fluid dripping from frame rails on both sides about even with the back of engine/front of trans. Considerably more is dripping from the drivers side. I wasn't in clothes to crawl plumb up under it & didn't have a light anyways. So I limped it home a couple miles & parked it. Had to manually downshift trans to slow down to maneuver turns but I made it.
It's still dripping a couple hours later. I'm only assuming the 235k mile front rubber hoses ruptured??
Thoughts?? Has this happened to others?!?!
