LB7: BPU's for the LB7
1,611
578, fuel only. stock turbo/pipes. But then the rods got tweaked...
Erniet67
Jul 13, 2012
3
Danville,il
fixed your spelling-gauges & recommend
modded regulator
A few other things that might not add any power but frees up restrictions-intake heater removal,drivers side manifold & fuel pickup
On #6 is that 32psi pre or post intercooler?
What is the fuel pickup on #6 is that a mod or did I read it wrong
714banshee380
Dec 14, 2012
32
360 rwhp trans starts to hate you? say you have a efi live max tune for stock trans say a 90 HP will that put you at about 360 give or take a stock lb7 has about 260 to the wheels?
DirtyMax32
Sep 11, 2013
139
modded regulator
How do you remove the intake heater on an LB7
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Noreaster
2,910
42
Cape Cod,MA
disconnect the wire, tape it up, remove the heater out of the Y-bridge
use a intake heater delete or a 24valve cummins oil drain plug
it will throw a code when its below 50*, shut it off with efilive
DirtyMax32
Sep 11, 2013
139
Alright thanks. I'm going to order my delete today.
Rico
Wheeler
Oct 21, 2012
69
Burlington, ON
Sorry, but what is the benefit of pullin the IAH? Does it restrict air intake flow or just disrupt it enough to remove? Will it effect cold weather starting?
Noreaster
2,910
42
Cape Cod,MA
frees up the intake, 2.5" tube with a 1" coil sitting in the middle
it was for emissions & makes no difference for starting
bonomax
223
Hermitage, PA
exactly correct. its pretty restrictive and frees up flow. also it makes no differance in start up in cold weather and that was made for emission to burn fuel more completely in cold weather.
only downside ive seen of not running one is in cold weather. lets say like 30 degrees F and below it takes longer to for truck to get up to operating temperature. which makes the truck use more fuel and hurts performance until its up to operating temperature. so when it starts to get cold out like now, i take out the plug and swap AIH back in.
