Blown turbo seal
YoungGunDiesel
Jul 19, 2017
45
Holy cow! I just replaced injectors cause I didn't know a blown turbo could do that much smoke!
I feel pretty dumb now.
The following photos are my truck and what made me now think my turbo is blown.
Sent from my VS995 using Tapatalk
Dozerboy
4,813
394
TX of course
The oil in the piping is normal because of the PCV. The smoke doesn’t look good though. What made you think you needed injectors?
Hambone
Always learning
Jan 24, 2016
572
Florida
X2
I've drained about 6oz of oil from the intercooler or roughly half a water bottle :(
There's a write up over on DF about it but the pics no longer work...stupid photobucket lol here's a decent YouTube video for the walk through on a pcv reroute job that eliminates oil in places it shouldn't be https://youtu.be/6NMB9FXLKFQ
Have you checked the balence rates?
YoungGunDiesel
Jul 19, 2017
45
What made me say Injectors was I had my heads checked and don't have head gasket issues. So I replaced all 8 injectors this weekend and it still smokes. And the only thing left is the oil in the turbo that I could think of
Dozerboy
4,813
394
TX of course
Where did you get the injectors? I advise more troubleshooting before you just start throwing part at a vehicle.
YoungGunDiesel
Jul 19, 2017
45
Well the new turbo doesn't cost me anything. It would be a free fix as I have another turbo. But I got the Injectors from injector direct.
4,956
pull the down pipe off. if its coated with oil, its for sure a turbo. if its not, pull the intercooler cold pipe (one that goes into the y-bridge), start the truck and let it idle for some time. see if the smoke goes away, if it does, its cause its pulling oil from the intercooler that is most likely full of oil. i would also take a pic of the intake where the PCV enters and let us see how much oil is in there. if there aint much, the turbo is leaking into the compressor side. if there is a bunch, you have a blow by issue.
YoungGunDiesel
Jul 19, 2017
45
Only got to taking the photos for you and pulling the. Pipe to the intake and it smokes same amount even after 15mins of idling. Attached are the photos.
YoungGunDiesel
Jul 19, 2017
45
Does that smoke smell sweet? It doesn’t look like burning oil
This will sound weird but you ever own one of those lyonal train sets as a kid that put out fake smoke? Exactly like that. But more simply put it smells like eye burning diesel.
Columbus450
260
Louisiana
Looks like oil to me , if it was coolant it would be white and dense and would fall to the ground as soon as it came out
Black obviously unburned fuel
Bluish burnt oil
To verify it's not a stuck open injector try to disable one at a time and see if it goes away
Also get a temperature gun and laser each cylinder at the manifold and see if the temperatures are with in range
YoungGunDiesel
Jul 19, 2017
45
Bluish burnt oil
I shall do that and write back. Although If it's oil getting into the fuel and if it isn't compression or turbo. Could that be a bad valve seal?
Also here are the videos of my truck,
This one is last night when I took the pipe off the Y bridge like recommended
https://youtu.be/O3CE9MRL8bk
And this is when I first thought I needed injectors and hadn't changed them yet.
https://youtu.be/-JwYlRdnW_Q
Columbus450
260
Louisiana
Are you building pressure in your radiator? What does it do while running with the r. cap off , in the video it looks a lot whiter
But it would be distinctive it would smell sweet if it was coolant you said it's burning your eyes like fuel?
YoungGunDiesel
Jul 19, 2017
45
The coolant just kinda sits there. With the cap off or on. No bubbles and doesn't fluxuate. The radiator. Hoses dont get solid or sucked in. Nothing odd really. And the smoke looks whiteish to me as well. But it turns brownish and grey/blue the more I give it throttle but the overall color is white to me.
