:screwy:
:toilet_claw:
hgeez:
a leveling kit is not a lift kit, maxed out it will provide close to 4" of height adjustment, more there for compensating for additional weight on the front end, such as a plow, however without that extra weight holding the front end down, bumps will be bone jarring on the complete opposite end of the spectrum of comfortable, and your front end parts will be out of their optimum settings and wear out much faster....if however you chose to run the kit at less than +1 1/2 inches it will ride smoother than stock
As far as 4" lifts go
Cognito makes a very nice lift available with the no torsion bar drop option:thumb:
Rancho makes a nice lift
And iirc...
Trailmaster and tough country make a nice 4" lift
Skyjacker makes a lift
I run a cognito 4" lift w/bilstein 5100's and the ride is supple and comfortable, personally the valving is a little too soft for me, if I had the coin I would've upgraded to the Fox shocks...
I used a DEAVER 2"mini pack in the rear and with the overload removed I have 1 1/2" of rake but it looks level, in hindsight a DEAVER 4" leaf pack might have been a better option, however, I have helper bags in the rear, so I don't have to worry about loosing my stance with a load on
but I maybe would've preferred to have a tiny bit more rake
While allot of people will say they like and may prefer the ride of their truck with the torsion bar bolts removed, I personally don't like it at all, IMHO I feel like set up in this fashion our trucks feel like they are "numbed or slushy" feeling in the steering and responsiveness of the front end and just a tad bouncy...I feel like the torsion bars are there for a reason and need to be in the proper adjustment for the suspension system to function optimally, so IMO, I personally wouldn't remove the torsion bar bolts on a 6" kit, for daily driving duties anyways...
I know lots of guys do it, I'm not saying anything bad about it/them, just that I personally wouldn't...
