I am just curious about what kind of batteries everyone is using? Right now I am using the stock AC Delco. Thanks.
Factory batteries in my truck...When they die, Napa Orbitals will be going in their place.
Make sure it's a good NAPA dealer, not just some schmuck that plays on the internet all day :joker:
:rofl::rofl::rofl:
:rofl::rofl:
Can you please post up some info on the Napa Orbitals? The only one I could find online was the Napa Legend 75 month. Thanks.
:rofl::rofl::rofl:
x2Stockers and will likely be replaced with stockers, depending on price.
Thanks partsguy, the second link doesn't work, I think it says catalog expired or something like that. What are the cold cranking amps on the Orbital?
Either way you go, I wouldn't go with the stock batteries.
What we found by running a higher quality battery is that they recover from abuse better.
Let's say you drain your battery down to where it won't start your engine.
With a really good battery, you should turn everything off (disconnect it if possible) and just let it sit there for 20 minutes and try again. Often it will now start. Batteries will recharge themselves if there is zero drain on them. Try it sometime.
The better the battery, the more it recovers. One time, I left the headlights on in my van overnight. I turned them off, then waited 20 minutes and it started. But it was a better battery than stock.
Another thing is how many times you can kill it before it won't hold a charge anymore. Stock batteries often won't survive a half dozen attempts on it's life, but the better batteries can be killed again and again.
