Bad fuel sending unit?
DreksDmax
Apr 23, 2019
23
Shithole Cali
Hey guys just bought an 08 LMM from local Chevy dealer. Truck has 80k miles, one owner. Filled up last night for first time, had about an 1:8th of a tank, filled up with 15 gal, I’m assuming bad sending unit or gauge? Seems to be a common issue with these models
Thanks in advance
skintback
Take this one to church
Mar 5, 2007
919
Florida
LMM's are very bad about the fuel gauge being way off. I have taken the sending unit out and bent the float arm to get it to read where you want it like 3 or 4 gallons left and then the low light comes on
I think you can adj it with EFI live as well not 100% sure on that
1,751
GM has it like this from the factory. Light comes on with something like 10 gallons still in the tank. Supposedly to reduce people from running out while towing
You can make some adjustments with EFILive but there is a section of the table that is low resolution so you can't get it where it should be without bending the arm some to make it operate in the high resolution section of the table
There is also the possibility of yours being bad too
DreksDmax
Apr 23, 2019
23
Shithole Cali
Interesting. My pops also has an 08, he never lets his go below 1/4 tank and says it takes around 17-18gal at that point. So if my gas light comes on I should have around 10 gal left and 100-120 miles plus left? So my range is not accurate either. At fill up last night the range said 270 miles. Is that about right?
1,751
I've never really paid to much attention to range but I know my gallons used is never off by more then a gallon when I fill up so that is what I normally look at.
I installed a different sending unit then factory and scaled the table to turn the light on at about 4 gallons left. I almost always fill up with the light on and I've fit 34 gallons in the tank many times
Before I would only get 22-24 in with the light on. But I ran out twice trying to estaminet how much left before stopping to fill up
DreksDmax
Apr 23, 2019
23
Shithole Cali
Guess this time I’ll see how low it goes before my light comes on
Dozerboy
4,812
394
TX of course
On my 08 when the fuel sending unit went out it started going crazy. It would read full then a few hrs later it would read 1/2 then maybe 3/4 an hr later. Now my trucks run all day so it’s easy for me to notices these things. Might be harder if your not in your truck all day.
