Hello all,
I am doing a standalone swap and I scored a 2007 6 speed Allison from a wadded up DMax truck with 21k miles on it to use behind my fairly tame 12V Cummins.
I have an 01 5 speed TCM and wiring harness, matching NSBU (2 plug jobbie to match the harness), and I will be using an SAE #3 bellhousing with the TC speed sensor. I want to use the 5 speed TCM because I have it, and because it is relatively simple to run stand alone. From what I have been able to learn, nobody has gotten a 6 speed TCM to run standalone, mainly due to the difficulty in getting a suitable OS from Allison without an OE application
So, since I have a 6 speed trans and a 5 speed TCM, I have a few questions. First off, do the 6 speeds have the same internal wiring and solenoid shift combos as the 5 speeds? I.e., does solenoid D on give you 1st, none on 2nd, C on 3rd, C and E 4th, E 5th, D and E reverse, and all on for P/N?
Second, THEFERMANATOR told me that the G solenoid can be left disconnected without any adverse effects. Not that I dont trust him but I wanted to verify that with Mike.
Finally, the last question is one of curiosity since my manual only covers 5 speeds: Assuming the solenoid combos for 1-5 on the 6 speed are the same as a 5 speed, what solenoid combo gives you sixth
Thanks!
Greg
Thanks!
Greg
