Finally got around to installing my air dog 165 that has been sitting around in my garage for a while. Install was a breeze, even for a mediocre at best backyard mechanic like myself. I like how high up on the frame it mounts. Cant see any parts of either filters hanging down even when standing way back. Engine sounds happier, could tell it was starving a little for fuel before the install.
Anyways my questions are:
1. If pump stops working will it still have positive flow through the lift pump with the OE fuel pump?
2. Do the pumps come pressure preset?
The only way I see to verify is to buy a pressure sensor and run it off the lift pump threaded port. Am I missing something? Desired and actual rail pressure off my monitors would not be an accurate reading for determining if the lift pump is pumping the fuel it needs to be, correct?
