calculating injected quantity per stroke
Pat:
I too would like to know this. I'm trying to do alot of figuring on the new motor i have, and i like to see my tuning ideas backed up with a little math, just so i have a true idea of whats happening.
Basically, i would like to know the same thing. how much fuel per shot. Given that there are lots of variables (exact fuel rail pressure, etc.) - there are still some knowns.
For example, i know that i have 30 over injectors - i had each tip broken down and flowed, so i know that the injectors can flow 26 liters +/- about .125 of a litre.
Also, i know that i put the LBZ regulator on my single CP3, and ported the fuel rail fittings. While it doesn't increase PSI of the rail really, it does increase the volume. this changes things of course when you factor in 8 injectors all open for x amount of time - as the capacity of the rail diminishes from long injector pulses, PSI of course will drop.
But what i really want to know - for a baseline - is the formula for figuring out, if possible, how much fuel is injected just as in the example given. 24000 psi @ 2500 msec pulse width = ??? mm3? If there is some base calculation to this, i am going to try and figure out given the size of the injector (allowed flow) how much fuel is being squoze out. I'm going to take it one step further when i get reasonable comfortable with calculating this # and throw in timing and other engine / tuning paramaters so that i can 'see' where in the stroke the injector opens, and given the pulse width, where in the stroke the injector closes (all of course dependent on other variables).
To me, if i can figure out the math, i can build a handy little windows application to mimmick the functioning of the motor for tuning purposes. It'd be handy for me... as i'm a believer of getting the fuel in the bowl - and i even know the sizes of my fuel bowls... the spray pattern is the one piece of informaiton i dont have (calculating the size of the patter and a given distance from the injector tip)...
Anyways - i have some ideas - more to be aids to tuning these things - but i need some math to help back me up. i know i'll have to study my ass off to figure it all out, but i think it could be a pretty handy app for the hardcore tuners, and for wanna be's like myself. It could at least help a tuner make sure they were tuning as efficiently as possible once i get it to that point. the math is the hard part, the windows app is the easy part.
Let me know what you have. Any and all parameters you might have for such a formula would be greatly appreciated..! Or that ANYONE has access to..
Thanks!
-->Zach
