About to purchase 09 2500
jham0077
Dec 24, 2022
Florida Panhandle
I'm about to get an 09 GMC from my dad and I'm looking to lightly tune it it will be a daily driver. I've tweeked on my 13 gas burner a little with good results and I'm looking forward to the diesel tuning. I'll be doing a lot of lurking here.
1,754
If you are doing it yourself then it should be doable. But you will not likely find a professional turner anymore.
Reactions: jham0077
jham0077
Dec 24, 2022
Florida Panhandle
I don't wanna roast tires off of it or smoke people out. Just looking for a little better shifts and throttle response, maybe fuel mileage. I think I can dig enough info up to manage that.
1,754
It's all here in the forum. May take a little digging and a ton of reading but you'll find what you need
Reactions: jham0077
08lmm72mm
528
164
Saskatchewan, Canada
Stock tcm tuning will yield the best shifts, making sure your fuel system is running 100% from the tank to exiting the injectors is key. Changing the allison have 'firm' shifts will only shorten friction life.
Reactions: jham0077
jham0077
Dec 24, 2022
Florida Panhandle
So no firm shifts with the Allison? I guess that makes sense with the torque of the diesel opposed to the gas engine.
I gotta get the truck first. It's in Alabama, I'm in Florida. It's either a lot of traveling on my behalf or we split the difference and meet halfway. It may be a month or so if I gotta make the whole drive.
1,754
Hard shifts on an Allison means shortened life which is also an indication of bad tuning or mechanical issue. Shifts should be nearly unnoticeable
Reactions: jham0077
660catman
119
I’m new to diesels and have no experience in tuning or the need to tune. I had a 2013 Silverado 5.3 and towed a fair amount between campers, sled trailers and boats. I can tell you it’s a world of difference with a diesel. Empty I got 26.7 mpg on the same trip I’ve done many times and got 18 mpg at best with the gas truck. As 2004LB7 mentioned, shifts are barely noticeable.
Drive the truck for a while and see whether you need to spend the money on a tune. BTW, my truck is all stock.
2013 Sierra SLE 2500HD Crew Cab
Reactions: jham0077
