A/C controls inop
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
35
Goodyear, AZ
Batteries died in truck, after charging them and firing up the truck the AC controls work but will not change through the positions, hot/cold blend seems fine, fan speed works, won't change from defrost to any other position. Is there any way to recalibrate or reset this?
Thanks
4,953
Not on the 01-02 that i ever found. Mine were either stuck blend doors (like just barely enough to not move but a little bump got them moving) or the di-electric grease caked up on the blend motor and wouldnt let it contact anymore. Ferm told me about that a while back.
mine use to always be the air direction (vents, floor, defrost) or the recirc/outside air.
CarolinaHD
969
NC
To reset the HVAC, pull the fuse for a minute and reinstall, turn the key but dont start it, wait around 2 minutes for it to do its thing. You should hear the blend doors moving and it'll be on auto mode.
4,953
EDIT: ignore me here, facts are later in thread
Is it as simple as cleaning or were parts required
Yup! Had to take the actuators all apart.
13,598
632
01-02 2500hd and 3500 never got auto air so that doesn’t work for us. It’s all manual knobs
I'm pretty sure I've seen an 01-02 HD truck with automatic HVAC controls before (it isn't digital, but it has temperature settings and an auto position). It must have been a very rare option though. Either way, there should be a way to calibrate the blend door control since it is electronic. I don't work on those old junkers much though :poke:; if I had one here, I would go out and try it to see for sure. Good luck!
4,953
Was it a suburban/Tahoe retrofit? Oddly enough, I have two ordering books here from when my dad ordered the 02 I have. One book (one he ordered out of) says this (S is standard, O is optional)
Then the other book that I think we picked up later says this
Maybe later 02’s got it? Mines August 01. Honestly never seen an HD with auto climate control though
Don’t be jealous my truck is still younger than you and in better shape
I’ve tried the “reset” method a few times with no luck.
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
Could the batteries being weak cause this? I know you charged them but we all know these trucks get stupid when voltage is off
Also yes James I can’t confirm off hand of 01s had it but I’ve seen several HD trucks with auto climate control. It’s funky looking for sure. Far left control is for blower speed but it’s more like a rheostat instead of set positions and an auto function. Center is your temp. Right is your vent selection.
4,953
I’m starting to remember this discussion before.... I keep thinking of the digital display and that’s not the case
dndj
Boost!
Apr 13, 2019
302
33
Oregon
Got curious based on your ordering books James. Found a couple 02 crew cabs in LT trim with the "automatic air" on a various used car sites. Picture of this HVAC panel attached. I've never seen one of these before.
13,598
632
I have not seen many, but I know I have seen it because I remember thinking how odd it was.
1,606
I want to say my first 02 Dmax had auto climate. My wifes Blazer did. Thats the panel for them.
KyleC4
470
Bay Area
Just wanted to chime in. My 01 Sierra SLT 2500HD has auto climate control. But I’d agree I don’t see it on many vehicles during that year range
4,953
Now that we are completely off base and Sean will have to just deal with that :rofl:.... is it only Crew Cabs LT models you guys have seen them in like the book says or were there any extended cab or LS models with it?
zakkb787
<that’s not me...
Sep 29, 2014
2,340
Granite Falls NC
Never seen an LS with them before, but if I’m not mistaken I have seen a fully loaded extended cab with them BUT I can’t say for 100% certain because I look at so many trucks.
CarolinaHD
969
NC
You dont seem so sure, Administrator :D
From the 2002 service manual, same for manual and automatic controls:
4,953
well that was before i was proven that the AUTO air came in these trucks :roflmao:. btw, ill never know it all on these things. if you aint learning something new, life is no longer interesting
OregonDMAX
Apr 28, 2013
3,964
35
Goodyear, AZ
I have an LT crew cab 10/01 (02)
So what's the verdict, how do I fix this haha
