LLY: 911: new bcm and now it will not start
dirty_max
815
eureka il
ok guys, we just put a new bcm on my friends truck and now it will not start, and also the radio is locked. im not even sure where to begin so any help would be much appreciated.
battlegraduate09
Gearhead
Mar 18, 2010
610
its security issues. Thats why it wont start. You can do a manual relearn and get the truck running.
Try this
1. Insert ignition key and turn to the “ON” position. Do not attempt to start the engine. Leave
the key in the “ON” position for approximately 11 minutes. The security light will be steady
on or flashing for the 11-minute period. Do not proceed to Step 2 until the security light
turns off or stops flashing.
2. Turn the ignition switch to the “OFF” position for 30 seconds.
3. Turn the ignition switch to the “ON” position as in Step 1 for 11 minutes.
4. Turn the ignition switch to the “OFF” position for 30 seconds.
5. Turn the ignition switch to the “ON” position as in Step 1 for 11 minutes for a third time.
6. Turn the ignition switch to the “OFF” position for 30 seconds for a third time.
7. Turn the ignition switch to the “ON” position for 30 seconds.
8. Turn the ignition switch to the “OFF” position.
9. Attempt to start the engine.
and yes you need to program it with the tech 2
dirty_max
815
eureka il
well that blows since this is a cat shop and we dont have a tech 2 lol. can he plug the old one back in or will he have to have it towed to a dealer?
battlegraduate09
Gearhead
Mar 18, 2010
610
yes that is the point.
like pressing the accelerator 3 times to reset oil life and other tricks you can do without the "correct" tools
programming with the tech 2 will marry all modules together
OregonDMAX
NOT IN OREGON, NO DURAMAX
Apr 28, 2013
3,964
35
Goodyear, AZ
Far as I know that manual relearn works on all gm product from the 2000's
I've used it on a caddy a Chevy 1500 and a dmax it works.
