67 c10 duramax build
13,599
632
Cool build. Are those Weld Renegade wheels I see? They look just like mine except yours are still chrome, and they don't look like 20s.
TMAN
95
29
They are 18 inch renegades
Sent from my SM-G930V using Tapatalk
13,599
632
Very nice. Don't see too many pre-American Racing Welds anymore.
TMAN
95
29
Passenger side mount moved, also got the passenger side frame cleaned up where the mount was. I can't feel my hands at the moment so I'm going to do the drover side tomorrow.
So naturally I had to lower it down and see if they would work. Right now it is just sitting on 1×2s ran across the rubber cab mounts. It will be mounted about an inch higher than you see here.
TMAN
95
29
Got the box sitting on the frame. I don't have to raise the floor as much as I had planned. I'm going to notch the supports for the box ~2.5 inches and then raise the bed floor 2 inches because it too simple to not do it because it all just bolts together. It should cover almost half the frame. I've always hated the amount of frame showing on the hds.
TMAN
95
29
I dont want all that frame showing like this one
TMAN
95
29
Nothing is squared up right now, but you get the idea. Still need to raise the bed floor 2 inches so I can get it sitting a little lower on the frame.
TMAN
95
29
Got both sides welded up, only have the drivers side plated right now.
TMAN
95
29
Haven't been on in a while. Took a break from working on it while we were seading. So it had to free up the lift.
Then I found a set of welds on Facebook while sitting in the tractor, bought them and polished them up.
And how it sits now, on the rotisserie doing rust repair.
Sent from my PH-1 using Tapatalk
TMAN
95
29
More cutting tonigh, cab corner is pretty much fitted just have to cut some more exces metal off before flanging the metal to lay the new sheat metal over top. Would have liked to have gotten more done tonight but I got off work late.
All the crap that was inside the cab corner
