4x4 end play
JDPlowboy
624
Since I can't find a thread on the subject, figured I'd start a new one for future 4x4 housing swap references. Truck recently had a new extension housing installed. A few hundred miles later the truck quits moving on its own. Dis assembled trans and found the rear thrust bearing between output shaft and sun gear was destroyed. So I'm
Guessing the rear end play changed with the new extension housing. There is a shim between the spacer collar and rear bearing. I was told they have 1, 2 or 3 holes in them to specify thickness.
I had to replace p3, sun gear and output shaft. Re used the same 2 hole washer and I can't get any end play out of the output shaft. Does anyone have any experience with this?
JDPlowboy
624
Since you tighten the output shaft to the rear bearing, I'm guessing one would have to take an H gauge and get measurements from extension housing down to output shaft then measurement from rear of case down to thrust bearing and figure the clearance?
JDPlowboy
624
This is what I came up with
Trans is on a stand with tailhousing up so the planetary gears are resting on the c3 backing plate.
Then I backed the spanner nut off so the output shaft can float freely between rear thrust washer and rear housing bearing. Zero'd the mic with the shaft sitting down on the thrust bearing then I'm prying up on the spanner nut so it pulls the shaft up to the rear housing bearing. The end play is measured at .022". Atsg manual calls for .018-0.32" so I'm calling this a satisfactory measurement.
15,686
There will never be play at the output shaft once the rear nut is tightened. End play is checked at the input shaft. The selective washer at the rear will determine what your end play will be.
JDPlowboy
624
When you pull up on the input shaft your just lifting the c1/c2 clutch housing out of the p1 planetary right? Or would you check endplay on input shaft with tailhousing up and be pushing in on Input shaft?
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Sounds like the extension housing was changed without pulling the trans. This is a common outcome when you do them without pulling the trans, and it almost always ends up like this. Many still swap them in the truck to try and save the labor, and then this happens. Without pulling the trans, you can't verify the clearances, or be certain that the thrust washer doesn't drop down.
15,686
Why do you not believe me? You are pissing in the wind doing what you're doing.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,322
359
Central OH
The planetary gears "float" inside the trans so to speak.
JDPlowboy
624
If there's anyone out there I'd believe over anyone else it would be you.
Just wasn't sure how checking the input end play assures that the rear thrust is ok. I don't wanna just replace parts and say it's fixed. was hoping to find a sure sign as to why it failed.
Truck was a low on trans oil but still on stick. Metal in the pan, dropped trans, rear thrust bearing was gone. Trim valve a and b were stuck. Pump looks good, clutches and clearances are all good. Cleaned everything and got it back together and on then road. Just wanted to make sure the endplay wasn't too loose or too tight
4,907
it was due to who ever replaced the tail shaft housing and not pulling the trans, tipping onto bellhousing, and then replacing it.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
It takes time for things to chew up in there when something is put in wrong. I followed the wrong part of the ATSG manual and put the one torrington in upside down(my gut said it was upside down, but I followed the book). 30K miles later I pulled it out and it was only slightly scored inside of it.
JDPlowboy
624
Ya the rear thrust tho is one that has a collar and if it was upside down the collar would be supporting the shaft instead of the bearing surface. Now that this one is correctly assembled it shouldn't have anymore problems
WolfLMM
Making Chips
Nov 21, 2006
4,005
25
AL
It's been a long time, but I remember one being upside from the factory on my 01. Don't remember which one it was but had 150,000 on the truck, never been in trans. I called Mike and told him how it came out, wondering if I some how flipped by mistake, he told me the correct way to install it. No problems either way.
