4l80
clrussell
pro-procrastinator
Sep 23, 2013
5,912
375
I acquired another truck last weekend. Early 90s 6.5 auto truck
Trans was rebuilt a couple years ago by a local guy, shift great and all works as it should until it gets warm. And you’d probably never notice the problem other than towing in a field where you pull it down into low gear.
If you do pull it down to 1st or 2nd it won’t hold back after the fluid gets hot.
Anything easy/ common to look for? Is it something that can be fixed in the valvebody or is it deeper?
This trucks primary use was a farm truck for the last 10 years, and honestly will be just a beater for around town so if it’s to major I’ll probably just run it as is because I don’t really need it to hold back unless it’s hauling hay down a mountain with no trailer brakes.
pic for reference
13,599
633
They have an overrun clutch that does engine braking. If there are no other problems, I wouldn't worry about it.
15,686
Could be rear band. The reverse band lugs are known to push themselves out of the case.
