35 gallons in 6 miles...
Lbz Joachim
Broke Spender
Oct 1, 2014
St. Clair, MI
Well it happened to me. Luckily i made it where i needed to be before i went empty. But here is my issue. I turn the key on (lift pump starts pumping) and fuel just starts spraying all over under the truck. I checked the lift pump lines that go into what I'm going to call a "fuel junction box". Its located on the inside of the frame. That is the source of the leak, but i don't know the name for it or where to start on fixing this.
Anyone have this happen before? any info will help!
9,903
149
Fuel junction box? Got pics?
Sent from my D5803 using Tapatalk
Lbz Joachim
Broke Spender
Oct 1, 2014
St. Clair, MI
I don't have pictures as I'm not 3 hours away from the truck, i can try and get some in a few... Its tucked in the driver side frame behind the T-case.
Awenta
4,090
CT
Looking at the abs?
Maybe a line behind it rusted through.
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,032
243
At Da Beach
Sounds like your looking at the fuel cooler. I'll bet that hokie fitting they used to give you lost that clip that holds it into the fitting. It happened to my LMM, I used Monel wire to secure it after that...
9,903
149
This area?
1,600
Dale, I dont think that cooler was working very well. Holy clogged-with-dirt!
battlegraduate09
Gearhead
Mar 18, 2010
610
Same thing happened to me on a lift pump with maybe 6,000 miles on it. Blew the line off the factory return line. Lost 22 gallons in 4 miles.
Bikey
Corvette Racer
Mar 18, 2013
17
Brooklyn
There is a hard-to-flexible fuel line junction near the ABS module - You can either get quick-disconnect to AN hose adapters or put in replacement hardlines (which I did, they also include the flexi lines). It is not particular difficult or expensive to swap out the OEM lines for good braided teflon or rubber lines. if you use braided rubber lines, make sure they are rated for mild vacuum (most are).
Bikey
Corvette Racer
Mar 18, 2013
17
Brooklyn
I got mine (in stainless) from Fine Lines Inc. $345 on ebay for 2wd 2006 3500 dually. You just need basic tools and a quick disconnect tool (the NAPA ones work, not all of them do). It is a messy job and isn't particularly quick, but with stainless you will never need to do it again.
9,903
149
It it's just the flexible part on the fuel line that's leaking just get some hydraulic hose with compression fittings on it just like people use on the trans cooler lines. Cut it off at the hardline and done.
Burn Down
Sep 14, 2008
7,093
Boise Idaho
^^^ this. Mini tubing cutter and 1/2" compression fittings.
Bikey
Corvette Racer
Mar 18, 2013
17
Brooklyn
Agreed on a smaller scale fix if your lines are in good shape. My brake lines were in bad shape and didn't want to pull everything off to do the fuel lines in the future.
