2024 2500 with max tow package or 3500. What is the difference?
tcfulmer
Aug 10, 2012
I'm looking at purchasing a 2024 high country. I know everyone is going to say to just buy a 3500. Not arguing about that. I am wondering why. With the upgraded frame and springs, what are the remaining differences? Brakes, shocks, axles? What else makes going to a 3500 the way to go besides the increased towing and payload?
1,741
Historically it's only been the rear suspension leaf pack that's different, not counting DRW, C&C and other models. And the GVWR stickers. If they deviated from this in 2024 then i am unaware of it
4,952
Back in 2020, the difference was only the leaf pack and badging. I doubt it’s changed much now
I chose the 2500 because I didn’t want the 2 overload leafs if I decided to lift or lower the ass end. Plus I could always add air bags or the leafs myself if I wanted
tcfulmer
Aug 10, 2012
From the employee pricing web site, the max tow package adds the following.
  • 3500 HD Frame
  • 3500 HD Leaf Springs
  • 12" Rear Axle
  • 3500 HD Shock Package
  • Gooseneck / 5th Wheel Prep Provisions
  • Bed Stamped Holes With Caps Installed
  • May Require Additional Optional Equipment
Hope you can see where my questions are coming from. with the 3500 frame, leaf springs, axle and shocks, I wasn't sure what the difference would be to a 3500.
1,741
I'm guessing the frame is just the brackets and anything else needed to accommodate the additional overload leafs. If you look at the difference, you'll see a second set above the normal one that rides on some higher up pads
The leaf springs are kinda self explanatory
Looks like the 3500HD does indeed have a 12" ring gear and full torque in first gear, or no torque management
Different shocks for the stiffer leafs
Gooseneck and provisions are available on 2500hd also
1,741
For 2020 but still good information. States the 2500hd is 11.5" rear while the 3500hd
is 12"
And no torque management in 1st for both models
Some sites seem to state this is only for the DRW models. So...
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,033
243
At Da Beach
I think it is the same just listed as a 2500 for tax purposes. I got the max trailering package and it rides great unloaded still.
Hoser
233
30
Farmington, MN
It literally is just a matter of what the sticker says on the door jam. For some uses and in some states the tax can be higher for higher GVWR, so the 2500 with the Max tow package gives you the ability to tow the same as the 3500, just with the 2500 badge on the side and a lower number listed on the door jam.
4,952
Iirc the 12” diff is drw only. May be wrong but I’ve not seen a 3500 srw with the 12” yet per vin attributes
tcfulmer
Aug 10, 2012
I went back to the employee pricing configuration page and did a 2500 with max tow package and a 3500 configured identically. I'm going to do a line by line comparison when I get a chance to see what the differences are. I'll list them here once I have the results. The difference in price is $354.
