2015 lml i need more power
rauls17
Jun 19, 2015
i just recenlty picked up a 2015 denali 4x4 tuned it ppei lift pump and deleted i need more power i just came from a 6.4 power stroke raced a deleted 2015 dodge already had 4 truck lenghts on him poor dodge raced a new 2015 power stroke last night deleted and tuned he won one i won one now i need more power
first I'm looking to get into the 700 750 range i know trans needs to be built
for fuel i was going to go with a cp3 10mm stroker pump do i need injectors ? is the 10mm enough fuel supply ?
now for air i was looking at the basic add a turbo kit from industrail with the s475
is that enough air for what i want
looking to be as simple as possible and bolt on ass possible
Bonestock
1,358
Worland Wy
Exergy 10 mm pump will easily handle 700-750 worth of fuel. You may want some larger sticks @ least 45%s.
GMC_2002_Dmax
The Still Master
I tuned a 2015.5 with a CP3 conversion and a S475 over stock and on a small PW/Conservative timing tune he made 650HP at the tire easily on stock injectors.
You goals are easily met with a CP3 and twins of 700 RWHP for sure.
Your rods and head gaskets will be happy for sure..........:thumb:
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,033
245
At Da Beach
Stock LML injectors flow a lot of fuel.
Yep, no need for bigger sticks...
:rofl: The truth hurts...
Or costs...:D
Djreversal
72
I'm doing the 10mm cp3 and twins next week on my 2015.... trans will be the next piece.. I'm told like 650ish could be expected.. I'm told a set of 60% over sticks and u will get 700+ out of the stocker and keep your pulse width in a good spot. I think if u really wanna go over 700 u should probably swap the stocker with a 3794 and twin it
Awenta
4,090
CT
Trans should be first. Internals will be hurting too
Djreversal
72
Yea.. the trans should usually be one of the first things to do... I don't really ever beat on my truck so i should be ok for a bit. Ill be ordering my Torque Converter shortly... Hopefully get the rest of the trans stuff together by the 2nd week of July.
joelc79
Aug 27, 2014
I have PPEI, FASS 150, full exhaust, Fleece 750 cp3, and a GodSpeed true LML drop in charger, as well as a Dmitri trans with a 1058 converter. Did 611/1127. Plenty of fuel on hand as that hp was on my street tune. The maxx was way over fueled so been data logging to improve tune.
For reference..
