2012 LML overheating (new) Fan Clutch not engaging P0483
GrabAnotherGear
LML/Moto/Boosted Sleds
Apr 19, 2017
5
Utah
2012 LML totally stock, besides H&S mini-max and Fass 150.
When pulling any sort of load up a grade even in 30 degree weather, the truck overheats (coolant and trans temp) and the fan clutch never engages on high. I can never hear it engage and when I pull over to try and cool it down, the fan is very obviously spinning slowly, not engaged. No CEL, but scanning for codes pulls up P0483 "cooling fan rationality check malfunction". I figured it was a bad fan clutch, so I replaced it from a dealer purchased, brand new clutch... No change. 2 separate new relays... Also, no change. I haven't been able to find any information or schematics/wiring diagrams that are readable to troubleshoot the electro-viscous fan.
Turning the A/C on or whether the truck is hot or not doesn't force the fan to come on. Cooling stack is clean and coolant is pretty fresh.
Any help is greatly appreciated and so would any wiring diagrams for the circuit be really helpful?
Also, would a tech from a dealer likely be willing to plug in a techII and force my fan on to see if it works without charging me labor? (Takes 2 Minutes).
Thanks!
GrabAnotherGear
Apr 19, 2017
5
Utah
Thanks!
I went and got a copy of the schematic/wiring diagram from the dealer and took a picture with my phone.... When I figure out how to post it, I will. The fan appears to be controlled by pulse width modulation from the ECM. Maybe the issue is internal to the ECM?
Sent from my S60 using Tapatalk
1,778
Stick a meter on it and see what you get. May be tricky without having a reliable way of making it turn on unless you can run some wires into the cab and take it for a drive
If I'm not mistaken, I believe that all it does is power an element in the clutch that causes it to heat up and engage. You can probably check for ohms on this. Dont know what the resistance should be
GrabAnotherGear
Apr 19, 2017
5
Utah
LML cooling fan wiring diagram:
torqued2dmax
646
Brookville, PA
Im sure you checked the ground to the fan and the 10 amp fuse but did you run a jumper across the plug on the coolant switch when eng up to temp ? I have heard of those switches doing strange things and maybe with your tuner it suppressed codes ! Have you tried a Tech 2 yet ?
1,778
From the looks of the schematic, there is no way it could be PWM driven. That would make it easier to diagnose. Just an on/off driven relay control
5,037
start tracing wires, bet you got some that are broke. wouldnt hurt to check fuses and the relay as well. a power probe would make diag this pretty easy.
GrabAnotherGear
Apr 19, 2017
5
Utah
When the Tech 2 is plugged in, this is what it comes up with when you try and communicate or command the cooling fan on. Any thoughts? Maybe that GM tech is setting up the tech 2 is a moron? I guess I better start tracing wires.
Thanks for the responses so far.
Dallas S
485
33
Alberta
Try telling the tech 2 it’s a 2011
It’s common practice to run the 2011-2014 on a 4094OS, which is a 2011 OS
Scarface39
New Mexico
Have you tried replacing the coolant switch, not sure if its just a coolant level switch or level and temp switch?
GrabAnotherGear
Apr 19, 2017
5
Utah
I haven't tried replacing the Coolant Level sensor, although I did jump across it with a wire and there was no change. Even as the truck was running, when I unplugged, put back in the jumper, then plugged it back, no indication on the DIC. Is that weird? Should it have told me coolant-low or something?
Also, I haven't had the chance to try the Tech II again using 2011 as the year.
I may go out and buy a Snap-On Solus edge tonight, if it will pretty much work as well as the Tech II.
Thanks for the input so far!
kiwilml
454
The other day I was trying to pull a trailer in some mud and my coolant got pretty hot. Fan didn't come on till around 230 and then shut off right away when cooled down a little. It was sitting at 225 and fan was not on all the way didn't sound like. I'm interested to here some input on this also.
Victor
Sep 23, 2020
Did you ever figure out what was causing this? My 2011 just started doing the same thing.
