Allison 5sp: 2011+ Pitman Arm puller
clrussell
pro-procrastinator
Sep 23, 2013
5,907
363
I use a cut off wheel, cut a notch almost to the shaft. Then take a chisel and split it and it falls off.
Saves pulling the box down. Takes about 30 min total.
Doesn’t answer your question, but it’s functiona, time saving and free.
02greysixer
1,829
North Central FL
How I do all of them. It helps to have a half worn down wheel for the last little bit by the box. Usually one good brap from the air hammer in the cut and off it falls.
Sent from my SM-G960U using Tapatalk
04chase
222
i have the snap on one thats $300 , used it once when i didnt have a cut off helping a friend lift his truck.
but i too usually slice the old one down near the taper . falls right off with the heat from an abrasive cut off.
