pull a stock tune from a truck and start looking threw it, you will find what you are looking for pretty easily. you will also find the stock tune is very detuned from a stock LBZ tune. you wont really be able to optimize the stock tune without gaining power. The normal timing, boost and fueling tables will look just like your LBZ tune but the limiters will be WAY more than your stock tune.
i tried two "optimized stock" tunes in two different Kodiaks (one an 07 and the other 06). One was a 5500 Seneca motorhome, i made it about 75% of what a stock LBZ tune was and he lost the converter in 2 trips (was pulling the long grade into san diego when it started giving up the ghost). Other was a Reg Kodiak a guy used to haul his 45 ft warrior toy hauler. i told him i could make him 3 different levels, a 55%, 65% and a 75% or more if he wanted (55/65/75% of a stock LBZ tune in a light duty truck) but the stock trans will not handle the weight and the power. he wanted the stock LBZ tune loaded. Said alright but its your trans funeral. made it out of his drive and onto the freeway on ramp and limped it into 5th. We went back to a 55% over tune for the time being till he got the trans built.
