2006 Lbz leak at front of trans.
Flopo
May 11, 2020
Rebuilt this trans 4 yrs ago. Maybe 20000 miles. Sun coast, trans go jr. transgo kit to up pressure. Goerend converter. Shifts good.Had a leak at front of trans. Changed all seals o-rings and gaskets in front. Put back in truck and still leaking. What else should I be looking at. Converter shows no signs of leakage.waiting on a small bore scope to put through lower inspection hole to see if I identify leak. Is there anything that would increase the amount of fluid pressure in the area behind the seal. Thanks for any help.
Flopo
May 11, 2020
Forgot to add that to list. Old one looked good. Installed a new one anyway. Mike is the area behind the seal a low pressure area, that bleeds fluid away from the seal. ? Where if the seal was in to deep it could build pressure and not drain and cause a leak at seal?
