LBZ: 2006 Cab and Chassis Tune
Kriesel
Apr 2, 2013
25
Afton, MN
Need a tune for a 2006 Cab and Chassis Duramax truck.
Swapping a 2006 Duramax into a 2003 Suburban, and need the cab and chassis tune for the dual fuel tanks.
clrussell
pro-procrastinator
Sep 23, 2013
5,910
364
Send me a pm with your email I've got one
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Do you one better. This tune was setup to use the stock 03 rear sender/pump assembly, but an LBZ pickup sender assembly in the front tank. It's a 4X4 with dash indicator(if you wire in the signal wire to the ECM for 4X4), factory dual tanks already calibrated for the listed senders, you just have to rewire the transfer pump circuit which you will have to do regardless.
http://www.thetruckstop.us/forum/resources/lbz-duraburb-fuel-system-file.26/
Kriesel
Apr 2, 2013
25
Afton, MN
Oh man, you rock!
Been working on building a pdf of the swap instructions. have most of it laid out now (60 pages or so lol)
Next I'll re-activate my alldata account and get wiring diagrams for what needs to be done. Then start swappin. Not going to make a build thread in DP till I'm done probably.
