2005 lly
nitrochad
33
3
Wi
Hello I am looking for help with my truck. Truck idles fine. Starts out fine. But once it gets warmed up it sounds or feels like a miss. No codes. Fuel filter changed. Without codes I have no idea were to start. 124,000 miles on truck
1,754
Measure and report:
Desired fuel pressure
Actual fuel pressure
Main fuel rate mm3
Balance rates in park and in neutral
Air flow in grams/second before and after running rough
Engine temp before and after it start to run rough
Air temperature
Crank and cam sensor missed pulses
nitrochad
33
3
Wi
I am thinking it's the fuel psi regulator. I will get u the numbers you are looking for. Idles fine. Balance rates are good. Max 4 on #1
1,754
Inspect the harness where it run by the alternator. Also try the ice pick trick or new pig tails on the injectors. Particularly 2 & 7
nitrochad
33
3
Wi
Pictures. Injector balance rates are from 0 to a max of 3 on #1 cylinder all the others are lower. Just cruising along frp actual and commanded is 70, truck runs fine.
nitrochad
33
3
Wi
1,754
It's also 18 years old. You may want to replace the rubber fuel lines on the engine. You can use a clear test hose after the filter to see if you have air in the line
Reactions: 1FastBrick
Bdsankey
3,913
1,074
Neenah, Wisconsin
