2005: Key FOB lock works but unlock doesn't
thunder550
1,176
Phoenix, AZ
Trying to figure out what's going on with my dmax swap truck. All of the electronics are from a 2005.The keyless entry remote works to lock the truck, but generally doesn't work to unlock it. When I first got the truck running, everything was fine. It worked great for lock and unlock for a month or two, then all of a sudden the unlock function stopped working, but the lock function continued to work. I changed batteries in the remote, and did the relearn procedure but no luck. Every once in awhile, the unlock will work, but usually not. Any ideas?
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
First try taking the remote apart and clean the contacts on the rubber button membrane.
If that doesnt work, get a new remote. They are like $15 on ebay. Its definitely not a problem with the truck...if it was a problem with the receiver in the truck, then nothing would work.
Ben
